Recently one of the speakers has stopped powering on when the Denon amp is switched on. The light on the affected speaker remains red while the light on the other speaker turns green. Swapping cables makes no difference, the same speaker keeps failing to power on.
At the weekend I realised that the speaker will turn on and produce sound if I power it off/on at the mains switch after the amp is switched on.
I have seen reports of other types of failures due to "foam rot". Is this likely to cause the behaviour I described? Any ideas how I can fix it?
