BeoLab 8000: On Line/RCA input, always red LED ?
Problem I have a BeoLab 8000 (serial 14xx xxxx) with the following issue.
  • When connected via RCA: the relay does not click in when a sound source is active.
  • When connected via Powerlink: all works well both switching on as switching back to stand-by.
  Things done/checked
  • Foam-rot: there was foam rot, but everything has been cleaned. I have checked damage to copper traces on the PCB's with magnifying glasses. No damage has been detected.
  • Audio source & cable to RCA/Line: I have used different audio sources and cables. The input of audio signal is OK.
  • PL/Line selector: Checked if it is in the right position for Line.
  Tested from Service Manual (and others)
  1. Supply voltage: measured P2 Pin 2 to TR3 Emitter = 14.94v, P2 Pin 2 to TR4 Emitter = 15.07v
  2. Voltage between R83 and R86: measured 12.04v.
  3. Voltage TR11 Collector to P2 Pin 2 = 0.03v.
  4. P2 Pin 1 to P2 Pin 3 on PCB02 = 45v.
  5. P2 Pin 2 + TR1 Collector = 3.7v (I think it should be < 0.5v ?).
  6. P2 Pin 2 + TR 1 Base = 0v
  7. P3 Pin 1 + Pin 2 = +/-24.5v (I think it should be +/-15v).
  8. P1 Pin 2 + P3 Pin 1 = 52c AC (not sure what it should be ?).
  9. TR1 Base + P2 Pin 2 = 0v at Stand-by.
I think item 5 and 7 show the wrong values.   Tests focused on the Auto-start circuitry Found input to test continuity between P7 Pin 2 (GND) and different components associated with the Auto-start circuitry.
  1. TR7 Emitter to P7 Pin 2 = Yes continuity
  2. TR8 Base to P7 Pin 2 = Yes continuity
  3. R81 to P7 Pin 2 = Yes continuity
  4. C47 to P7 Pin 2 = Yes continuity
  5. C65 to P7 Pin 2 = Yes continuity
  6. TR9 Emitter to P7 Pin 2 = Yes continuity
  7. R84 to P7 Pin 2 = Yes continuity
  8. Tr11 Emitter to P7 Pin 2 = Emitter No, Collector Yes, Base No continuity
Item 5 did not result in measured continuity.   Question
  • What can be wrong, and how can I solve that the Auto-start will switch again on the RCA/Line?
  • Might it be IC1 causing this issue?
In addition I did a test on the Input selector switch on PCB05, I measured all positions of the switch with a multimeter. And then did the same with a switch on a PCB05 from a working speaker. In comparison all results were the same. I also swapped a PCB05 from a working system to this speaker. Results the same; in the RCA position the LED stays red. To be continued when I received IC1. In the meantime, still open to suggestions that help problem solving.
I can't offer any specific repair advice for the BL8000. However, I can provide some general advice based on a repair of a BL4000 with a similar issue. Based on my initial inspection, I didn't think that I had an issue with foam rot, but I was wrong. I found several places where there was either open circuits or higher than expected resistance in the traces. Some of the telltale signs were black spots like in the picture below. Other places had white(ish) colored spots or were at the edge of a solder pad. The most insidious corrosion was where a trace ran under another component. Some of the breaks were not apparent until the area was cleaned with a scratch pen. I narrowed down the spots to examine in detail by installing needle tips on my multimeter probes and setting the meter to measure resistance (as opposed to using the "continuity beep"). This picture shows a few of the steps in the progression of the repair. Note that the traces under the black spots ranged from being OK, to being partially corroded, to being completely corroded. Hope this helps some, Glitch
Whilst I have not needed to look at a Beolab 8000 for a very long time, I took time to remind myself of the workings of the circuit. To answer your last question first, the problem could be IC1 and I noted you have tested all parts of PCB5 by comparing with a working unit. Given everything works perfectly with a Powerlink connection is helpful because that reduces the area for investigation considerably. The problem is almost certainly going to be prior to R85 on PCB2 where it feeds the base of TR9. The reason I say this is because where you use the Powerlink to switch on the speakers it forces the collector of TR16 which feeds the other end of R85. If you have an oscilloscope I would look at the anode of D17 which is also the junction of R136 and the collector of TR17 with and without a signal at the phono input. If you only have a multimeter, then the best way is comparing voltages between a good unit at the bases of TR14, TR16 and TR17 with and without a signal at the phono input. See attached circuit diagram of the area of concern Let me know how you get on..
@Glitch: Thanks for your input and especially the visualization. This helps understand what to look for. So I will check again.   @Keith: Also thanks a lot! TR14, TR16 & TR17 In the meantime I measured what you suggested. Since I do not have an oscilloscope, I used a multimeter (Voltcraft VC130-1), in diode/continuity mode. IO found out that the direction of TR16 on my PCB is 90 degrees different than the layout in the Service Manual. But I assumed the Base to still be the left leg of the two next to each other. You can see the results below. In all measurements, no continuity signal but a value measured. Measuring at TR16 with & without signal on RCA, the relay switched on. With audio signal on the RCA, music was also there.   Additional In the schematics of PCB02, I read that IC1 should measure +15v at leg 8, and -15v at leg 4.
  • I measured 29v.
As IC should also measure +15v at leg 8, and -15v at leg 4, I checked that one too.
  • Also 29v.
  Question:
  • What does this mean to you?
  • In the meantime I have also received a new IC1. Do you suggest to execute the replacement, or do you have another suggestion?
You need to clarify your use of the words diode/continuity mode? We are testing the DC voltage at each of these points..
@Keith: thanks, I guess I misunderstood. So I re-measured with the multimeter in DC voltage. Also, I did the same measurement with a speaker that switches correctly on the RCA/Line-in. This is what you meant?
This is exactly what I mean't, thank you. Clearly it is difficult without a scope and doing these voltage checks can only be a general guide. However the 0.8 volts DC at the base of TR14 is much nearer to what I would expect. It is starting to look like IC1 or one of the associated resister/capacitor around the IC could be at fault or well out of tolerance. Before you change the IC1, lets do one other check by removing R136 add a input to the phono and measure the DC voltage at TR14 base again.
Thnx Keith, I will di that check and report it tomorrow.
Here's the results of measuring TR14 at Base, after removing R136. Curious to learn what the results mean.   R136 removed.
