Beolab 8000 distance installation
hi, is there a recommanded distance between two beolab 8000 in stereo. Which is the minimal and maximal distance? I saw on homecinema forum a distance between 2-4m for front loudspeaker. My earing position is at 5 meters from the loudspeakers(but I have not the possibility of 5 meters between the beolab 8000). thanks.
If you have video source/tv in between or just want to have a funtioning stereo imaging from where you sit, the speakers should not be too far apart. The further they are apart the harder it will be to find a sweet spot for listening. If you have a video source/tv a center channel will help. MM
I have mine 2.5m apart and my seating position is 3.5m away. In a perfect world my seating position would be closer. As it is, I have excellent sound stage imaging in this setup which is strictly 2 channel stereo. Bill
