Beolab 7.2 repurpose
I am thinking of using my now redundant Beolab 7.2 with a BeoSound Core. Would it be possible to power the Core from the Beolab 7.2? Thanks in advance.  Paul
Hi Paul, Yes, it is easy to connect the Beolab 7-2 to a Core, you just need this cable:- https://soundsheavenly.com/bang-olufsen/31-325-rj45-to-powerlink-compatible-all-in-one-cable-convert-new-2013-ethernet-powerlink-to-traditional-8-pin-din-powerlink.html#/9-length-18m Please note that both the speaker and the Core each need their own mains power connection. Kind regards, Steve.
Steve, Thanks for this,  I will contact you when I go ahead. Have I misread the beolab 7.2 manual when is says "Mains connections The loudspeaker has two sockets concerning mains supply. The socket marked ~ is for mains supply input (connection from the wall outlet), and the other is a mains supply output to BeoVision 7 ", I thought I might  be to power the core from here.
Hi,   the Core could be connected to the Beolab 7.2 with a power cable with the matching connectors ( two C7 plugs ). It's the same way the Beovison 7 is connected to power, except you use a Core instead of the TV ;)
Thanks for that, it was I thought but wanted to check. I thought the core had a USB-c power connection.
