As you can see in the picture, there is +5V on the input board where the power link is located.
So I soldered a wire from pin 4 on P20 to the powerlink pin that requires the trigger signal.
Now the speaker is on constantly.
I made a power link to 3.5mm cable, and I can now connect anything to the Beolab 7.2 without anything else.
This is being mounted under my LG 55 in the bedroom together with a bluetooth module.
