Posted February 25, 2025 at 16:21 GMT
One additional thought about your setup: If you are indeed using the Essence line-in for your TV sound input (from your hdmi arc extractor), then you will have to go into the Essence setup menu, go to the 'Sound', 'Line-In' setting and tick the little check box to 'disable delay'.
The little note above the 'disable delay' box explains why you need to do this as follows: Sound from line-In connected sources is delayed in a Multiroom system. Therefore, when used with video content, picture and sound is not synchronized. The delay can be disabled, but sound from line-in can then not be distributed.
