beolab 6000 repair with end of 3500
hello, my beolab 6000 has a scratch. As I have beolab 3500 just lying here, can I swap one of the ends of the 3500 and use as a top of the 6000 ?
My god, "a beolab 3500 just lying here…", criminal.    :D Service manual show different part number but the look like very close with the same groove and have the same way of mounting, two prongs and a screw in the middle. If you have booth at hand, I would take measurements and try my luck.
Hi Filipbrugge, Do you have a deep scratch? I have experimented with a chrome type of repair marker. It worked quite well to cover the deep scratch damages.
thank you for the reply, the 6000 has a little dent on the side - I will try to swap them and keep both working ;)
