Beolab 5. When you need help with your ICE module
When you think that you're having a faulty ICE module(s) in your chassis and as they aren't available anymore (except for extremely high prices), I've made the effort to get them most reliable working order again. I've spent some considerable amount of time (and means) lately to fix ICE power amplifier modules from the Beolab 5 and Beolab 2. Made a test environment to measure and test the modules thorougly. Throughout the past years I've collected these modules and fixed lots of them and noticed that the culpritt can be on different places on the board. So I decided to fix a pile of modules and marked and made notes of each module. That way I've collected notes over 60 modules with at least 15 positions they can fail and got a pretty clear view which components fails the most and some less. This way every module can be reliable fixed when changing every possible weak component.   Keep in mind that a Beolab 5 (just as every other electronic product) can fail on more different internal parts, but with the knowledge that they can be repaired, my personal resistance to buy a set secondlife decreases significant. So, if you're considering a pair of BL5's. Just do it. After all, they sound amazing and have an unique appearance.
Beobuddy this is an awesome post. It's fantastic to see repairs at this level for Beolab speakers in general. I have dreamed of buying a pair of Beolab 5 personally but have worried about the issue of repairing the chassis. This adds considerably to my confidence in proceeding. Assuming you offer repair services do you have a website/contact info and wherebout are you located in the world? Cheers, Hyponx
I agree, that is fabulous! Are there - according your experiences - different behaviours, probabilities to be faulty given, when comparing MK1 and MK2 models?
Hi @beobuddy, My name is Henryk. I 100% agree with your statement: Beolab 5 sound amazing and have a unique appearance. To the point that recently I acquired pair of them (vintage 2007). They indeed deliver. One of those speakers is perfectly fine. The other one, I think, starts to exhibit issues that will cause repair effort in near future. Here is what I noticed so far
  1. It takes considerably longer time for it to finish autocalibration procedure (compare to working specimen)
  2. It stops reacting to commands from Beosound 9000 (It will react to wake up command but once operational the only way to power it down would be thru power cycle)
  3. It might be just my impression but it could be getting warmer compared to working specimen (judging by heatsink temperature at the back)
  4. If it gets warm if won’t start again even after power cycle. It needs to be left powered down to cool down for half an hour or so, and then it will start again.
This is what I noticed so far. It feels like there is an issue with its power supply that starts to affect stability of the system but I might be completely wrong. Here is where I hope you can help me. If you could guide me what could be done next to service/fix this speaker that would be very much appreciated. I only have access to what is widely available on the internet which is service manual. Since schematic, PCB files or BOM are not available, I would work completely blind here which might not be a good idea. In the past I did this:
Hi @beobuddy, One more observation from my side. If speaker that exhibits unstable behaviour is cold (in power down state) and I power up whole audio system it works as expected. There are no issues with reacting for commands from Beosound. Issues starts to appear when speaker runs for number of hours and I guess its guts to higher temperature. Is there a chance that some sort of thermal paste that should be present between components and their heatsinks is gone after 15+ years and this causes some issues? Any guidance is highly appreciated. Thanks for your time, Henryk
Hi there, I‘m a new member here, but a longterm lover and owner of B&O products. Starting in 1997 with BV28, BL8000 and later on BS9000. In 2000 BL1 and 2013 a dream came true: used BL5 from a B&O shop, SN 206…. & 207… SW 2.6 I updated TV and audio with an ‚almando‘ electronic, run without any problems till 2020: one BL5 chassis repair. The second BL5 get a new chassis in 2023. There are sound scratches, my description, and the B&O dealer send it to Denmark. I had to pay a big ticket, twice. So, now, since 2 weeks, I miss the deep tones :(, the auto bass meassurement didn’t work,  stop every time, pressing 25sec the top or unplug power for more than 10min doesn‘t help.  I’vve read a lot, before I found you here. Before I go to the dealer again, is it posssible to get help/repair here? I‘m a prof. IT guy since 35 yrs and think, with the service manual in hand, to dismantle the BL5 @beobuddy could you help here? seems you helped a lot, may me too? thanks in advance Gunter p.s. sorry for my english, it‘s rusty after not working in english envireonments
Hi @marexy Looking thru forums for Beolab 5 success stories I came across you. Did you manage to fix yours Beolab 5? What I wrote above still stands. At this point I basically completely powered down one of my Beolab 5. It is not completely dead but it feels like it is on its way out. Do you have any advises where to start repair of those speakers? Which components are mostly faulty? What to pay attention to? What to check (inside) using scope, etc? I guess there is no way to get schematic or layout or BOM for those speakers therefore any advice that could be shared here how to proceed with potential work to fix them would be very much appreciated. Thanks, Henryk
Like Beobuddy for some time now i rapired lots of Icepower moduls beside other repairs on B&O systems. BL 3, 4, 4000 Mk2, Bl2, BL5, BL11, BL7, ...ect.. There are no same faults. And here and there some crazy suprise error. Or some reapir faliure from DIY repair projects.
Hi @marexy Thanks for note. How do you start such repair? Are you looking for voltage levels based on block diagram or something? Any guidance where to start and what to pay attention to when doing so? Thanks, Henryk
@ Gunter. Does calibration starts with the microphone coming out? If not, then there is another problem. Most of the time the ICE amplifier for the lower bass is the culprit. But again, look at the movement of the microphone.
