New to the forum, happy I could join :)
Currently I have a pair of Beolab 5's. Connected to a Beosound Core with Powerlink and with Optical. When I first connected the Beolab 5's to the Core with only the Powerlink cable I got distortion from the tweeters.
The problem was solved when also connecting the Beolab 5's with spdif/coax cables. I just called a nearby B&O store and they told me that Powerlink should also work fine, without distortion. Maybe I don't have the right Powerlink splitter and cables.
Long questions short.. what is the best way to connect my Beolab 5's to the Core? Will Powerlink, using the right cables, also work fine and with maybe even higher sound quality than over optical?
