Posted June 6, 2025 at 08:00 GMT
I got a pair of Beolab 4 from eBay, in great condition - they look like new. I got the version which do have Powerlink sockets just in case I want to use them with any of my B&O HiFi equipment in future, but I bought them to use with my PC.
As it turned out, I already had a cable with stereo 3.5mm to 2x mono 3.5mm (I don't remember where it came from; I rarely throw a cable out). I connected them to my PC that way and they work fine. The volume is very loud, so for normal listening, my PC volume is set to only 4 out of 100!
The do go into standby if there is no audio from the PC for about a minute, and that's exactly what I want them to do - in fact the switch on the underside needs to be set to Line In for this, not PC. If you set the switch to PC they remain powered on all of the time.
It's difficult for me to tell if they are on standby or not as I am colourblind and can't tell what colour the LED is, but I have found a problem. Last night when I stopped using my PC, they did go into standby (while I cannot see the colour of the LED, I did at least see that the colour did change). I switched off my PC, but when I came back into my office this morning, there was an obvious buzzing/feedback from the speakers. This is the exact same noise as I get if I unplug the 3.5mm plug from the back of the PC, so must be some kind of earth/cable feedback? I don't have much understanding of these things though.
I'm wondering them if it could just be the quality of the cable. I think I'll buy Steve's cable that you recommended
That's odd, why is it doing that?
