BeoLab 3500: how to use the DIN connector as AUX IN
I have a BeoLab 3500 with serial 17xx xxxx, type 1601. I would like to use the DIN connection as an AUX Input. I have tried the following PIN connections (for the pin-numbers I refer to the Peter Pan picture below, so seen from the solder side of a male plug that goes into the BeoLab 3500):
  • 2 = GND, 3 and 5 for Left and Right channel IN.
  • 2 = GN D, 2 and 4 for Left and Right channel IN.
For selecting the DIN in the BeoLab menu I used:
  • 'Menu > Menu > 0 > 4 > Go'. This shows 'MCL SEL' in the display, but only gave a lot of HUM no sound coming through.
  • 'Menu > Menu > 0 > 3 > Go'. This shows 'ML ON' in the display, a slight hum, no sound coming through.
  My questions
  1. What is the right Menu operation to activate the DIN connector for AUX IN use?
  2. What is the right DIN-pin use to get the audio signal in?
You have an MK1 which has a different pinout. Have a look at little down in this thread that has the pinout for both the MK1 and MK2
link
Menu, 0, 4, go is the right operation. Note that when this mode is activated any remote command or button command on the BL3500 will make it go to standby
Hope this helps
Also you might take a look in my thread about these connections on the BL3500
link
Thnx Madskp!
You were right. I made a new Mini-Jack to DIN cable with the pin configuration for MK1 and it worked, when connecting a battery run iPod to the BeoLab.
Then I connected a streamer box via the same Mini-Jack to DIN cable, and that caused Hum on the left channel.
Any idea what to do about that?
Do you run 2 separate ground wires from the minijack to the Din connector? Then maybe that could be the issue.
On my testing cables I have connected pin 3, 5 and 7 (ground for MCL data) with a solder blob and just running one common ground
The cable just has 1 GND wire. The PIN connections I have now look like this:
  • 1 = Left (grey line)
  • 2 = Right (red line)
  • 5-3 = GND (black line)
  Question
  • So, do you mean I should also connect pin 7 with 3 and 5?
  • And that it should solve the Hum I am having now?
you could try to connect to pin 7 also. When the BL3500 is used in an MCL system all  three are connected via the cabeling. Also pin 7 is the only one with direct connection to ground in the speaker
Thnx Madskp.
I have ordered a 7-Pin DIN plug, to include pin-7 in the grounding.
Will come back with feedback when I have received and tested this.
Here's an update. Today I received the 7-pin DIN plug, so I have just soldered a new cable based on your advice. The pin connections now look like this: Result:
  • Unfortunately there is no change, I still have the Hum on the Left channel.
In this case an iPod is connection via the Mini-Jack > DIN cable.
  • When the iPod is powered by an USB wall plug, the Hum is there.
  • When the iPod is powered by its internal;l battery, the Hum is not there.
  Question: What other pin connections can I try to solve the Hum?
Are speaker and iPod charger in same power outlet ?
Try that !
Try different charger. In my case I reduced 'hum' by changing charger to an iPad charger.
