beolab 3500 and bluetooth streaming issue
Hello, I have a Beolab 3500 connected with a Logitec bluetooth receiver. I stream music with an Iphone 8. The issue is that the volume is very loud. If I set the volume on the Iphone at minimum its very loud. I checked the bluetooth settings of the Iphone. I'm using a cable from Soundsheavenly. Anyone a suggestion?
Have you tried using a B&O remote (Beo4 or Beolink 1000) to reduce the volume of the Beolab 3500?  It seems that the BL3500's default (switch on) volume is set too loud - a remote will allow you to reduce this.
with a streaming device you cannot use a remote to controle the volume, only with the streaming device.
and how is that done?
With a B&O remote control.
