my BeoLab 3 no longer works. A check revealed that the fuse and two SMD capacitors in the power supply were defective. Unfortunately I can only find the block diagram on the internet. Does anyone have the circuit diagram for the power supply or knows the values of the SMD capacitors?
Thank you :-)
Greetings
