Beolab 2000 as a blue tooth speaker
I own a Beolab 2000 that I would like to use as a blue tooth speaker. I have never used it as part of a masterlink system. It powers up but as I have no other masterlink devices connected to it, how can I establish if the unit is working correctly before buying the blue tooth adapter please? When powered up it shows two red lights either side of the display and pressing any of the function select buttons doesn't change the display. I would be grateful for some advice please.
Watch this video https://youtu.be/GqePgxGAEDA?si=5SHBoV2fnwAqqcYf Jump to 3m20sec That will give you answers
Thank you. Now I need to find the converter!
Here's one:
Still work-in-progress but:
Thank you very much I bought the converter.
