Beolab 2 NTC thermistor value
Hello everyone,
I've just bought a knowingly non-working BL 2 (red LED) on internet:
When turning on my Beomaster 7000, the BL 2 LED briefly goes from red to green and back forever to red (with the clicking sound of a relay).
The Powerlink cable used for this setup was tested on my Beolab Penta and is working correctly.
After opening the BL 2 I've discovered that the previous owner tried to replace the NTC thermistor screwed on the back of the woofer.
Since I'm not sure that it was done correctly, I would like to make sure that the right NTC thermistor was used.
Could someone please tell me what should be the value of this NTC thermistor at room temperature (around 20°C)?
Thanks for your help.
Best regards,
Axel
Hello Axel,
The NTC should read about 500KΩ at 23°C
PCB 48, NTC is still available as a new part if required.
Part Number 8100090
You can purchase this part from Multicare.
Cost £4.57 + VAT + Shipping.
You can contact Multicare here:
Peter Fraser
Service Technician
Multicare Electronics
