BeoLab 2: how to switch on without 5 volt trigger?
I am in a try-out project to see if I can drive a BeoLab 2 subwoofer wirelessly. This means that I have to connect the Audio-IN of the wireless module, to pin 1 & 4 of the Powerlink. This is no issue. What I do wonder about, is how to get the BeoLab 2 to switch from stand-by to ON. It needs a 5v signal to switch to ON.   Question
  • Any ideas how to get the stand-by to ON switching done, in this setup?
I don't think there's an easy way to do it, however some thoughts:
Thnx very much Guy & Carolpa! The Playmaker, BeoSound Core or Essence are unfortunately no options for this project. I am looking at a way to integrate the streaming completely inside the speaker casing. So no PowerLink cables, only a power cable and no boxes outside the speaker casing. So I wonder if the 5v triger is something I can create somehow inside the BeoLab 2.
This youtube video (https://www.youtube.com/watch?v=ivTnjK5mLV0) shows a product that seems similar to what you are planning to do. It might be small enough to be built inside the Beolab 2 (just guessing). It seems like the trigger is going on as soon as a line signal is received and turns itself off after 6 minutes with no signal. I wanted to buy two of these for my Beolab 2000s, but unfortunately, the provided eBay link doesn't seem to work. In case you find the product, please let e know.
@Matador Very interesting approach! This is obviously the way B&O equipment handles it. I would be very much interested in a electronics scheme, and make such to try it out. Any chance you know how such would look like?
It would look like a little box with line-in and line-out sockets and a 5V input (or whatever is need to start the Beolab AND power the box circuitry. Inside there will be a relay or something similar that would be triggered by the amplified Line-in signal (sound). The relay would have an auto hold loop with some sort of timing circuitry (I.E it would stick for "some" time when no sound is present and then open). Output of the relay will trigger or not the 5V to the Beolab. Now, Please note that I'm totally ignorant of how it could impact sound (since we're playing with the main audio feed, but as far as I remember my electronic classes, this is not NASA technology here.
Maybe something like this (the 5V trigger version) would be suitable:
Why don't you use a 'beolab trigger cable for this? Soundsheavenly makes them. powmasscables makes them. Or make it yourself. Put 2.5~5v on pin 4 and pin 7 for ground and all beolab speakers switch on...
