tournedos wrote:
From an engineering point of view, it makes absolutely no sense.
Please explain why it absolutely makes no sense. The person from the link I provided made sense to me from mechanical/acoustical point of view.
tournedos wrote:
But then again, I'm an engineer and not a high end mystician. I can appreciate it if somebody thinks they are hearing a difference, though, but I'm not falling for any of that...
Well, I think/hear the definite difference between belt drive and direct drive as far as cassette decks are concerned, in front of me.
tournedos wrote:
Anyway, that's completely irrelevant to the point, which is vinyl table drive.
Please explain why it is irrelevant to the point just because it's a vinyl table drive. Physics/acoustics of why belt-drive is sonically superior to direct drive (unless one's willing to put far more effort to direct drive than belt-drive) still applies whether it be vinyl or cd or cassette according to the reasons provided from the link.
tournedos wrote:
Theoretically, I'm not sure I'm completely happy about how the mechanical noises from both the main motor and the servo are isolated from the carriage, ....
Please indulge me. How would you have done it differently?
tournedos wrote:
Can't comment on the direct drive generation, I've never really listened to them.
Well, I can after having listend to direct drive turntable too long. They suck sonically compared to well-tuned belt-drive.
tournedos wrote:
But really, you're comparing these turntables according to what you've found on YouTube? 😕
Indeed. The trick is to listen to a device in real life in front of you, and then listen to it again from youtube, and extrapolate the difference, after that, listen to other devices from youtube, and compare them to the sound of the device you're familiar with in real life as you listen to it from youtube.
This way, you can differentiate the relative, not actual, but relative sound quality of different devices.
Analogy would be this:
Obviously you know how Paul McCartney sounds. You also know how people who are not as gifted as McCartney sound.
Can you tell the difference, the relative voice/sound quality? I can, even if I have never listend to Paul McCartney's voice in real life in front of me, even if I have never listend to people not as gifted as McCartney in real life.....all from youtube.
Of course it helps if I listend to either McCartney's voice or the people not as gifted as McCartney in real life.
