Has your plastic cog still got a C clip holding it in place?
It is common for it to catch on the small metal plate that is part of the set down adjuster but I have never seen a deck where the skeleton rubs on the plastic wheel itself.
I think this is my exact problem. I have tighten the three screws, so the platter should be in highest possible position, but it still scraping at the end of the record.
The scraping stops if I lift the back of the tonearm (when the needle if lifted)
Help, please
Update:
Went out today and bought washers
Two M8 with some grease did the trick on my TX2
Got this and a Beomaster 1900 for £200 because of this problem
For me it turned out to be nothing wrong but one little embarrassing thing. Since the previous owner took the RIAA card away the he had to connect the signal cable directly to the mute-card. This is a bit to thick to be placed there which can cause it to touch the flywheel. This was in fact the problem in my case - the flywheel got tilted which I didn´t realize right away. I pushed the cable away and now it plays perfectly.
Thanks for the help even though the problem only was me focusing on the wrong side of the player =)
/Sven
