TX-2 subplatter scraping on plastic gear beneath
On my otherwise perfect and delightful TX-2, the aluminum subplatter is scraping against a plastic gear beneath it. There is very close clearance apparently.
Seems that either the plastic bearing is worn down or the subplatter has become warped. It might be easier to have the subplatter machined than to find a replacement plastic bushing. I tried to get the bushing out but couldn't figure out how.
Any suggestions?
Thanks in advance.
Hi
I have the same problem with my BG4500. Doesn´t seem to be adjustable? It also causes friction somewhere on the main spindle so the platter can´t spin freely. Is the bushing replaceable? It can be moved up and down but not pulled out of the "cylinder".
/Sven
McGruse wrote:
Hi
/Sven
This is a common problem and is adjustable. Do not try to replace anything.
The procedure is explained in the service manual which is available on site to silver and gold members.
joeyboygolf wrote:
McGruse wrote:
Hi
/Sven
If you refer to "turntable height and centering" in the manual that does only adjust the platter in relation to the top plate. I need to adjust the height of the turntable in relation to the driving mechanism.
McGruse wrote:
joeyboygolf wrote:
McGruse wrote:
Hi
/Sven
I think you will find that it lifts the complete mechanism up or down.
http://archivedforum2.beoworld.org/forums/p/14885/130545.aspx#130545
Does it rub all the time or only at certain arm positions i.e. towards the end of the record?
joeyboygolf wrote:
McGruse wrote:
joeyboygolf wrote:
McGruse wrote:
Hi
/Sven
I have some problems explaining it but it is the fly wheel (the skeleton one) that touches the plastic gear, and those are both part of the driving mechanism that adjusts together in that procedure.
Even if i lift the top cover to "service mode" it doesn´t spin as it should.
It rubs all the time 🙁
The plastic wheel that you are talking about is the one that drives the string?
Yes, as seen on this pic I found on Google. My player doesn´t have as much clearance as the flywheel on the picture. That´s the problem.
