Hopefully diverted an immediate problem with my TT arm dropping too soon and rolling off the LP without bedding into the groove.
Pulled the deck apart and wire-brushed the threaded drive bar. It looks like some residue had built up along the critical length adding resistance to normal play.
After cleaning, all works correctly. however, can anyone tell me if there is a lubricant and lubricant schedule for this drive bar.? I’m currently thinking that a minute drop of a light oil will do the job (hair or beard trimmer oil)?
Can anyone advise? Thank you
