Styli for Beogram 1000
Hi All, I’m looking around for a replacement/reserve stylus for my newly bought Beogram 1000. Sometimes I come across styli from Tonar, are they any good? And besides the SP6/7, can I use the the SP8/9 as well? In any case I’d prefer a elliptical diamond.   Greetz,
A.K.A Capt’nGerard on the Discord
Yes you can use an SP9 which has an elliptical diamond.
Ok, thanks. Another question; are the SP 6/7-8/9-10-12-14 interchangable between various SP based Belograms? I have a SP6/7 retipped by FJS recently with a Nude contact line elliptical stylus, and I was wondering if this can be used on any other later SP based Beograms? TIA!
Another question; are the SP 6/7-8/9-10-12-14 interchangeable between various SP based Beograms? The stylii themselves are Generally, yes.   Nude contact line elliptical stylus, and I was wondering if this can be used on any other later SP based Beograms.   Short answer - generally yes. But a Contact Line is NOT an Elliptical. You have EITHER a Contact Line, OR an Elliptical.
Electronics Technician in Jerusalem Israel. B&O fan for over 50 years.
Thanks, the stylus is indeed only Contact line and not elliptical. My mistake. I was wondering if I would buy a later SP based Beogram, I could use my newly retipped element on another Beogram like the 3000 or 1800 just for example. Because the retipping was more expensive as the Beogram 1000 is ever worth…
I was wondering if I would buy a later SP based Beogram, I could use my newly retipped element on another Beogram like the 3000 or 1800 just for example. Yes, absolutely - I have done exactly that for other customers. The early SP6/7 etc stylii fit just fine on a SP12/14 series cartridge, but with a small space, which I fill with a small rubber grommet. It looks just fine.
Here's a comparison of the SP10/12/14 (top) and SP6/7/8 etc (middle). The rubber grommet ensures an aesthetic fit on a BG120x/3000 etc tonearm.
But I can swap it along with the cartridge by plugging it onto the newer tonarm I asume?
I recently bought a SP10 like on the top of your picture with a broken needle, just to have a spare cartridge for €25. I’m keeping the needle/element for future retipping
