SMMC4 and a broken heart
I was able to find a SMMC4 locally through Craigslist. Owners tT had internal issues, that the cart did not fix. Now I hooked it up and am getting some noticeable distortion in the right channel. I noticed that the lever was to natuaraly sit a little to the side, the suspension seems to be fine, possibly sat on its side for quite some time. is there a way to get the lever to sit centered, or is this cart jacked? you can put very slight reverse preasure that it will straighten out, but will eventually return to off center. What is the difference in the tracking force between a SMMC4 and a mmc4? The seller told me that I can get refunded, if it does not work, as it has been sitting in the original box for 4 years.
Get a refund - this one sounds broken.
If the needle is not centred, it is very clearly a suspension failure.
If you did not pay a lot for it, you may not want to return it, but keep it, and send it to Axel in Germany for rebuilding to better than new condition.
In many cases it is the smart thing to do - buy a used cartridge for a little money, and send it for rebuilding.
Menahem
Electronics Technician in Jerusalem Israel. B&O fan for over 50 years.
I was able to get a refund and am now waiting on a new one from SS. Thanks for the help.
