Self healing beogram
I have three 800s and one of them has sort of a ghost in the machine symptom from time to time.
The left channel will loose some volume.  I've tried diff phono inputs externals and its not the amplifier.
The CD and radio are fine.
Its not the cartridge as I've got extras and they all do it.
It seems to be realated to how long its been on.  The fix is to turn off the turntable power for 10 seconds and then all is fine for hours.  Then it will happen again.
Just curious what would cause this?   And if I have to send it out is soundmith the best one to send it to in the USA?
THanks
I think some genius on AudioKarma suggested it might be a fault in the muting relay, but he is delusional
Well I'll take that with a grain of salt then.
Just wondering why a quick power off fixes it for a long time.   Probably not heat, maybe a capacitor.   I think the muting relay is to turn off the input when parked, that works fine.
The muting relay does not break the signal paths.
It merely grounds them.
There are no electronics in the signal path at all.
Any sound related problems will have to be caused by the cartridge, the internal and/or external signal cables
or the amplifier and speakers it connects to.
Thanks Dillen!
Well I only tried two different carts in it.  It is possible they are both weak as they are old.
I swapped the cables and finally the right channel went lower in volume.  Which makes it something from the Cart to the phono preamp connection.
I wonder why cutting off the power to the TT for 10 seconds fixes it for like 5 hours of play?    If its the cartridge do a voice coil develop a charge which is then sort of reset if you power it down for a few seconds?   Just trying to understand why it develops over a period of play time vs just being that way when I play the first record.    Usually takes hours and the fix takes a few seconds.
Or the preamp or the amp
Retired
Printing machine technician
Rock and Roll music
Collecting Vinyl
No not the preamp, I have tested with 2 different preamps same result.  And other components hooked to amplifier CDs, other TT run fine without channel drop.
Bad connection, solder or pressure. Cracked insulation... Making condensator to somewhere on the line... ?
I have a third cartridge I can try, that will rule out it being the cart.  (I hope its the cart)
