Hi, has anyone heard of people putting security tags on the canteliver of a stylus? And is it normal for an SP10 stylus to have blue paint on the canteliver?
Thanks in advance,
Pete.
Thanks in advance,
Pete.
As Peter suggests, the older SP's were indeed color coded, indicating the size of the rounding of the needle ("groove width") but I never saw a color coded SP10 and I've seen a lot of SP10's. My guess is that someone fitted an older stylus, SP2 most likely, in the SP10 cartridge shell which is possible and very easy.
Thanks for the replys. I suppose it is possible that an older stylus has been fitted, but the diamond does look to be in very good shape. Maybe it's not had much use. Is it likely to affect the sound having paint on the canteliver? I wouldn't expect it to if thats what they do from the factory.
Pete
