Hello fellow Beogram users. Happy to find this forum available.
I'm the second owner of a B&O Beogram RX2 turntable with an original MMC3 cart.
The first owner is a friend of mine and kept this platter in mint condition.
I've owned it now for a few years and it serves me well and still sounds amazing.
It has always had one little annoying problem, that is the Left RCA jack is starting to go bad.
If it's seated well on the female, usually there is no problem. If not the left channel signal seems weak.
If I touch the male ever so slightly, it buzzes out. The Right male does not do this.
Therefore, I'm considering replacing the signal cables.
The plan currently is to convert the fixed cable ends to a pair of quality chassis mount RCA sockets.
Utilizing the existing cable to make the connections from the PCB to the sockets.
Also add a solid copper Grounding Post.
This would fix the problem, and provide better flexability in cable choices and lengths.
I have many questions going into this project.
The first being...Has anybody done this conversion before?
Appreciate any advice regarding the topic.
