RX-2 tonearm wirering
I had to dismount the tonearm to fix a broken piece of plastic but did not pay attention to the 5 wires which is soldered onto the small board.
How on earth do I make sure i solder them back on correctly?
I quess I cannot just connect them randomly.
Maybe one of you guys now how the 4 sockets are to be soldered?I should then be able to measure which wire is connected to which socket in the end where the stylus is connected.
Observing from the front and comparing to a clockface:
12 = L
3 = R
6 = LG
9 = RG
You will need to use an ohm meter to identify which wire is connected to which pin.
Thanks Mark :)
