Restoring a BeoGram 3400 and a BeoGram 8002 QUESTION
You guys are so great.  Thanks.  I have a Beogram 3400 turntable that works OK and looks good EXCEPT the front piece of veneer is loose and needs re-gluing.  What kind of glue should I use?  Also, my BeoGram 8002 needs the double stick tape used to hold the aluminum plate around the platter AND the aluminum plate cover for the tonearm.  I was told that this tape is not available, so what do I use?  Both look great otherwise and everything works.  Thanks again.
I re-veneered a Beogram 1102 from scratch last year, and usedlink, with very successful results.
Andy T.
has there ever been a single one of this style of beograms where the tape has not failed?
you might try a high quality double-sided "servo" style tape... 3m makes some good products. i would suggest playing around w/ perhaps some card stock stacked like shims to get the thickness right, 'cuz once that stuff is stuck down -good luck!
hobby shops with a r/c section usually stock some...
I just use two pack epoxy glue for the 8002 - clean the black tape residue off carefully first.
