Replacement Beogram power and signal cables
Yes, iirc, Steve was the manufacturer of the BG4000c cables.  You should contact him.
Christian, you should realize that the 4000c has a line-level output since it has a built-in phono pre-amp versus a phono one in your 4000/4002. Therefore the screening and grounding are of more importance on yours. It is highly unlikely that Sound Heavenly manufactures their own wire but buys it in bulk from a supplier. What is it about the 4000sc's wiring that you find desirable?  I have custom-wired several hundred Beogram 4000x's in my time so could provide guidance if you'd like.
Hi Christian,
Yes, I made the cables that are supplied by B&O with all Beogram 4000c turntables, these cables are hand built and tested in my UK workshop. They are listed on my website at my sponsor link below. Please search for "Beogram" to see these cables.
Kind regards, Steve.
I want to replace the power and signal cables on my BG 4000 and BG 4002 with new ones similar to (or preferably the same as) the ones on the Beogram 4000c. Does anyone know where I can get them from? Did Steve, from Sounds Heavenly, manufacture them?
Any help or suggestions would be greatly appreciated!
Christian
I am also intrigued by this.  Steve do you supply the fixed cables or just the adapter cable to b&o ?  It is the  black braided fixed cables that interest me - I already have you excellent adapter cables.
Hi bulldog123,
It is the two blue adapter cables that I supply to B&O for the Beogram 4000c, not the fabric braided cable. These allow the Beogram to connect to any B&O multi-room smart speaker, or to a non-B&O music system.
