Question About Beogram 8002 Recapping
Hey all, I just got in a kit to replace all the caps in the 8002.
I'm a bit confused about the large cap on the board with its four legs. The kit I purchased included the instructions I've shared below, but for me the one sentence note isn't clear enough on how the new capacitor should be installed.
Is it correct to assume that between the two points connected with a blue line, I should install a wire? Then, install the cap in the two remaining holes (old center hole and the top hole)? If this is correct, should the positive leg be in the center hole? I thought that's how the old cap was installed but these instructions seem to say that the negative leg goes there.
Thanks for any clarificstion!
- Michael Archambault
The way that I usually do this is to install the positive lead into the center hole and the negative lead into one of the (blue) holes that needs the jumper. The negative lead should be long enough to bend over to the other (blue) hole to act like a jumper. Just make sure it doesn’t short anywhere on the backside of the circuit board. Glitch
Thanks, Glitch. Apparently I installed it the wrong way the first time. I've included a photo; let me know if that's what you were communicating. Ignore the bad looking solder job—it all holds up firm and has continuity. I'll visually touch it up when I'm done.
Unfortunately, now the machine isn't giving me anything. When I first got it, it turned on, moved the tone arm half an inch, then shut off again. Told it needed new caps.
Now, not even getting a standby light. Checked all the caps to make sure they're in the correct orientation and there are no solder bridges, etc. All the fuses also look good.
Primary concern are the connectors that are bare metal into black slots (like the two running from the CPU PCB to the main board). They fit into their respective spots and are pushed all the way down but aren't really secure and slide right out if given the chance.
Any thoughts? Thanks for any help!
Following up with some additional information.
Found a post on Beolover about checking the power when the 8002 shows no sign of life. They recommended checking the 5V regulator first, but I'm not sure on how to measure it.
Any detailed instructions are welcome on testing the 5v regulator or the power in general. I have basic soldering skills and know how to probe with a multimeter, but my knowledge ends there.
I’ve included a photo; let me know if that’s what you were communicating.
How you installed C27 is correct now. Beogram 800X's are usually straightforward to repair. Replacing bad fuses and fixing cracked solder joints is usually the first step. Then check the important voltages (i.e. power supplies). Replace any capacitors related to improper voltages. This will usually get the machine running again or at least showing significant signs of life. Getting specific advice on why your Beogram will no longer power on will be difficult. Advice like you found on Beolover's site are usually intended for machines that have died naturally. Since your machine had signs of life before the recap, I would concentrate on fixing cracked solder joints (usually on the cable connectors) and checking your work. I don't want to sound harsh, but the soldering in the pictures could use significant improvement. It might be worthwhile to buy a soldering practice kit" to up your game before attempting to do further repairs. Build the kit, see that it works, remove all the parts, then rebuild it again. Watch some YouTube videos to get tips. I noticed the missing solder pad for C20. This is usually an indication of someone that is struggling. It is likely that your machine can be salvaged, but the more damage that you inflict on the machine with bad soldering techniques, the harder that it will be to repair. Pretty solder joints aren't just for show, there is a structural aspect to it that ensures long term connectivity and reliability. Once again, I hope you take my advice in the spirit of giving you the best chance at a successful repair. Glitch
I appreciate the advice, Glitch. I left the comment about not worrying about the soldering in my photo because I had an issue with my solder station and consistent temperatures. To show, I've retouched the board now that the station problem is resolved. I've also included photos of my recap job. Is it perfect? No, not at all, and I will keep practicing (I struggled a bit with the wire not being though-the-hole)! But it's nowhere as bad as you might have thought initially. :)
Going back to the issue, I triple-checked my work: I looked for potential cracks, made sure the caps were installed with the correct polarity, and used a meter to test for continuity to ensure solid connections to points down the circuit— everything looked good. I also went through reflowing joints for all the major connectors. I think a component may have failed from excessive heat (I mentioned my solder station issue before), and I wonder if a cap has gone.
My plan at this point is to ensure power is flowing correctly, and I've been told that it starts with the 5V regulator. Any assistance or detailed steps to ensure the PSU delivers voltage and electricity flows would be welcome. I had to move the metal shield on the transistor I pointed out at one point, and I wanted to ensure the component is now working.
Hey Glitch, nice eye there! I've gone ahead and redone C24 as shown below. Another oddity that I noticed with this cap is that the board diagram shows reversed polarity compared to how the original was installed. Both the original cap and any repair work I have seen the other way. Thoughts?
I don't recall the exact details of this, but the apparent polarity" of the capacitor (as viewed from the top of the board) changes depending on whether one uses the wide or narrow mounting holes. Most of the time, one can simply match the orientation of the stripe on the new part to that of the old part (as viewed from the top of the board). However, this board has an unusual arrangement that needs special care. The negative pad of the primary hole is connected to negative pad of the alternate hole by a trace that snakes around and a jumper wire on the top of the board. It is hard to explain in plain text. The important thing to note is that the polarity marking on the back of the board is correct and the capacitor should be installed to match. Glitch
Thanks, Glitch.
I tried both methods shown below, and neither worked. I've left it in the 'A' configuration that you suggested.
Here is the 'A' configuration that you suggested.
Here is the 'B' configuration I see for other repairs, such as link.
20241002_221123
If I did want to test the power supply to ensure everything is working fine and test the 5V regulator, would you be kind enough to specify exactly where I should place my meter probes? Beolover provides a good guide for measuring across caps for the power supply, but I
