I have a problem with a Beogram 8000 type 5615, that I cannot figure out to solve.
It does the following:
When I press play, the arms move to the record, where they stops with the detection arm approx. over the first track of an LP. And then nothing else happens. It does this both with and without a record on .
Is this a known problem and for which there is a solution?
On the arrow keys I can move forward and back, but nothing happens when I press stop, where I would expect the arms to move back to the starting position?
I have replaced all capacitors with no change. Bought a kit from Beoparts.
The tacho disc has also been replaced. The old one was bad.
