Kind regards,
Rolf
Question: You are using a “Mini” buffer for the polish. In the Youtube video above the guy is using a “standard” sized buffer. Is there a specific reason, any advantages using a smaller one?I like this mini buffer" since it seems appropriately sized for the job. I have a couple of larger buffers and I would expect them to work just fine for most of the job. They would just be a bit less maneuverable. I also have a smaller buffer that is easier to get into tighter spaces, but I didn't have the need. I could have done the job with the smaller machine, it just would have taken more time. I have all of the buffers since I also restore cars and boats as a hobby. The deeper scratches are hard to remove. As you likely already figured out, polish will usually make a scratch less noticeable, but doesn't really remove it. Removing a scratch is better described as removing the material around the scratch to the depth of the scratch. Sanding is the most efficient way of doing this. But sanding leaves its own scratches. These scratches are removed with the next finer sandpaper, and so on until the scratches are shallow enough that polish will work. I exclusively use a machine for this job since I don't have the patience to do it by hand. I make my own ultrafine hook&loop sandpaper pads by gluing the ultrafine sandpaper to felt cloth and cutting it into circles to fit the backing plate. This is another place where the mini buffer comes in handy since it can be fitted with a backing plate that is similar diameter to the width of the sandpaper brand that I buy. One tip for hand sanding is to alternate sanding directions. By changing the sanding direction by 90 degrees, it is easier to tell when you removed all of the scratches from the previous direction. Marking the scratches with a sharpie can also be helpful. Sanding away the sharpie marks provides an easy to see indication of where and how much to sand. A bit of soap in the wet sanding water helps keep the paper from loading up as fast. Clean things meticulously between stages. There is nothing worse than picking up a piece of grit, introducing new marks and have to back up a step. If you feel as if you just fell down the rabbit hole, it is because you have ;-). Glitch
