The belt in mine literally crumbled to bits when I touched it. So, I have no idea what it was like. It is definitely toothed a bit like a zip tie.
Is there a source of replacements? If not any ideas on a DIY fix?
It's not a critical part.
The actual adjustment is done by the fingerwheel. The belt merely moves the small white pointer (that it seems nobody notices anyways).
