I hope some of the Beogram brains here will have an educated guess for what's causing this problem. . . .
As the subject line says, my friend's Beogram 1800--which I had previously brought back to life with the help of this forum--is playing noticeably off pitch. At first I thought that the platter might be rubbing against the chassis, throwing off the speed. But I adjusted the leaf springs and the problem is still there. Belt seems fine; it was a replacement from Dillen. I also checked and adjusted the speed for both 33 1/3 and 45 using a very accurate strobe disc and light (the Speedstrobe from KAB Electro-acoustics). Any ideas? 🤔
