MMC4 or MMC20EN Which is better?
IF your answer is the 20EN, will it work on my 8002?  It is currently on my 3400.  Please give some input.  Thanks
The MMC1 to MMC5 cartridges have a different fitting from the MMC20 series cartridges so you would not be able to swap one for the other.
The best option of all is to buy a replacement cartridge from soundsmith. They are not cheap, but by all accounts they sound better than the originals.
Simon
The soundsmith SMMC4 is superior (sound wise) to the original B&O MMC4. A very worthwhile investment.
It is also superior to the old B&O MMC20EN, but as Simon has already mentioned, it won't fit your Beogram 8002.
Chris.
