Hello,
Just bought from 'Leboncoin' a french 'Gumtree' equivalent, a new, unopened box, MMC20E cartridge, well that's what was stated. Here are some pics, tell me what your thoughts are.
Hello,
There seems to be a strange build up around the stylus where the diamond is attached
It is a good photo.
Regarding the debris, It could be some of residue from glue that was used to secure the stylus. It is out of the way where it would not interfere with a record groove. Try cleaning the stylus with a small strip of Magic Eraser Sponge. Only press the stylus directly onto the eraser sponge material...no horizontal movement at all. That should remove the build up of debris.
-sonavor
Thanks for the tip Sonavor, it cleaned up the stylus really well.
freddy
