Tonight I fixed my BG 8000. It now works but I just notice it's missing the weight adjust slider that goes on the outside of the arm. So until I can get one of those I won't be able to adjust the speed of the up and down cueing. Other than that, it works fine. Ran it through all it's paces and all button work fine. It looks like the weight is still in the arm but just missing the outer plastic slider. Maybe I will try to set the weight with a tooth pick and with a sure VTF scale.
I resoldered the main PCB the other night. Tonight I resoldered all the wires that run to the MPU box and resoldered all the caps resistors next to the cable and on the other side. Resoldered the replacement cap and made sure it was connected ground properly and to the casing. I also reseated the CPU.
After all that I hooked everything back up and plugged it in and at first it briefly went back wards when it was plugged in to the AC Receptacle but there was no humming anymore and I noticed the table was in standby mode. put a record on and hit play and everything worked fine except from the arm dropping a little too fast.
Now I can fixed these tables! :)
If I can set the weight via the Shure VTH scale then I will try to adjust the lowering function.
I just wanted to say Thank You to everyone for their help and info!
