I've never needed to do that myself, but on this 4004 I can see one more tab (and screw) on the right under the operation panel. Have you tried removing the panel first?
How to open a Beogram 4002 / 4004 / 6000
Hi Mika,
No I haven't, I was hoping there was some easier way than taking off the operation panel. Thinking that it might be as simple as removing the other panels which doesn't involve a screw driver. I am not so much lazy as fearful I might break something not knowing how to properly remove it. ๐
I wish Jaff would do this for the beocenter 3500 ;). Not much to find about that machine around here (besides the things i've asked for already), pitty. I'm not a hero when it comes to taking these precious machines apart (maybe not precious in money but certainly precious as a piece of inheritage). This step by step proces is very usefull for users of these machines!
I already did this for you almost (2) months ago!
I wish Jaff would do this for the beocenter 3500 ;).I already did this for you almost (2) months ago! HERE.
I'm very sorry, thy Grand Master. Forgive me and spare my life![:'(]
I was just talking about the visual support this post gives, but I'm not demanding anything from you at all! It was just meant as a joke. Dutch humor isn't appreciated here๐?
Can't we make this a sticky? ๐
A reasonable request! On the removing the wood surround, you don need to remove the control panel but after that it is just a case of removing the screws that hold the panel in the sliding position. There are plastic parts below the screws which are rather fragile but take your time and they can be re-used.
I just want to add a couple of little things - You should really follow the correct proceedure of bending the release tabs before moving the plinth forward. These lock the plinth in place which is why it appears to stick on some machines. By not bending these you needlessly wear them out to the point that many plinths just slide forward easily on their own accord.
Secondly, on re-assembly you might find some motor panels are a little stuborn and will not easily allow the plinth to lock into postition. This is rectified simply by lifting the panel up by a tiny (less than 1/2mm maybe but experiment!) amount and then sliding the plinth in should be effortless. Seems the keyhole can catch on the upper, larger diameter part of the pegs sometimes - maybe because it has become slightly bent out of shape?.. whos knows. Not worth messing with and once you know how to tease it in it isn't a problem!
@Mika and other Mods:
Should this "sticky" be converted to a Wiki for the new Forum?
Not a bad idea at all! We'll see about it once the ball is rolling, so to speak...
Register to access the forums, reference material, and exclusive member benefits โ including our monthly prize draw.
