has issues... Sits unlevel. feet missing? also platter sits so low the record scrapes the deck a bit. What's going on here? I tried to post pictures but they are too large.
Help with 1800
Apply new feets, check if transport screws are losened, if yes, adjust platter hight.
Reduce you pics to 640 bits horisontal length, to post, do like this.
Printing machine technician
Rock and Roll music
Collecting Vinyl
Thanks, I'll try to resize.
That worked.
Under the platter positioned where you see the 3 brass nuts on the pic you will find the transport scews, check if they are loosened and the platter mooves freely up and down, press the platter down with your finger. Check the platter hights, and if it mooves around free without noices.
Rock and Roll music
Collecting Vinyl
The screws are loose and the platter along with the whole bottom moves up and down but seemms it is sitting too low.
Adjust the platter hight like this, if you sign up as silver member you can download the whole manual.
Rock and Roll music
Collecting Vinyl
hmmm, That's interesting.
Thanks for all your help.
