Connect Beogram 4400 to a CD Player
Hi everyone,
I have a Beomaster 4400 and a Beogram 1700 that I've inherited, that are working perfectly. I linked a Chromocast audi using a Sounds Heavenly cable, and I'm very happy with the system.
However, I miss to listen my CDs. I wandt to buy a vintage Beogram CD player but not sure which model will be able to connect to the Beomaster 4400.
Any advice?
Thank you.
Patrícia
As far as I remember the BM4400 has 5-pin input connections (one for Phono and two for Tape).
Basicly you can use any CD player - in some cases you’ll have to use an adapter (R/L to DIN).
If you want vintage B&O….go for a CDX/CDX2 - which one is better the vintage specialist here may tell you.
There you have options for controlling directly on the device.
Thank you so much!!
Hi Patricia,
Welcome to BeoWorld!  Glad to hear that the cable I sent for the Beogram is working well.
You just need this cable to link any non-B&O CD player to the Tape input of the Beomaster as MM mentioned, this is the cable you need:-
https://soundsheavenly.com/bang-olufsen/52-72-stereo-rca-twin-phono-to-beosound-aux-input-din-socket.html#/2-length-1m
Any questions, please ask!
Kind regards, Steve.
Thank you once again Steve!
