One important piece of information regarding the MMC1-5 series cartridges...It is quite common for the suspensions on those cartridges to fail after all of these years. There are a lot of used MMC1-5 type cartridges around that probably have a good stylus and cantilever but don't work properly because of a suspension problem. Places like link and link here in the USA and Axel Schürholz in Germany.
I have heard that Axel is more or less retiring from the MMC cartridge repair and turning that work over to another technician mentioned here.
Those places can do a full restoration as well as just a suspension repair.
I only mention this so you are aware of the benefits and pitfalls of finding a cartridge. If you have an old MMC4 available I would start with that. It is a fine cartridge as other people here on the Beoworld forum give it good reviews. If you end up buying an MMC2 then I would look at the rebuilt ones from Germany as well as the new manufactured ones from SoundSmith.
-sonavor
