Compatability question for Beomaster 5500 and Beogram 5005 others
Hello, this is my first post on the forum so bear with me if I have missed a thread in the past.
I am the owner of a beosystem 5500 with beocord tape, beogram CD, and beomaster tuner/amp. I am currently bidding on a matching beogram 5500 turntable on ebay but the seller is being a flake at the moment. Will another series of beogram work with my beosystem? I have plugged in another older model of beogram from my grandparents set and it didn't really seem to have the amplification it needed to drive the sound I normally get from the rest of the system.
Long story shot - are there other beogram models that will work with my 5500 system and what are some options I should be looking for
Much thanks to all of you beophiles!
-Nick
Welcome to Beoworld 🙂
Any Beogram from the 5000 (radial), 5005 to the 9500 will work fine. In fact any B&O turntable from the 5000 on is compatible (i.e. remote controllable) with your system.
The 5000, 5005 and 5500 will match your Beosystem best on a cosmetic point of view.
Some say the radial 5000 is the best of the bunch. I use a 5005.
Thank you! What is the market value of the models you have referenced.  I had bid on and won a 5500 on ebay for 350. But I still haven't heard from the seller on shipping.
link
What you paid is a bit high, but then if it's got a fine MMC4 or better, and if isn't cosmetically challenged, that could be a fair deal.
These decks can fetch silly prices these days. Unless they come from professional sellers with a warranty of course!
350 USD
@Chartz Does that mean that a 6500 would work with my system?
You could, but it would be a poor choice for several reasons:
-It has an internal phono preamp, which duplicates the one in your receiver.   So you'd have to avoid the phono input and use Aux instead, which might not permit remote control operation of tone arm.
-It wouldn't match the other components cosmetically - it uses mirrored aluminum instead of matte, as well as a different lid.
-It would cost substantially more than a 5000/5005/5500 because of increased demand due to having a built-in phono preamp.  A feature you don't even want.
Your best choices are 5000 (radial), 5005 or 5500 (linear, no difference except for badge)
Exactly.
@MediaBobNY and @Chartz thank you for the great information! I'm sorry if I'm asking rookie questions. I've owned my parents system for about 10 years and I've just now decided to look for a matching turntable with the boom of vinyl again. In my city of Columbus, there are now 10 record stores that've popped up all over.
I'm going to keep looking for the suggested series of 5000, 5005 and 5500.
I really thought I'd nabbed a good 5500 off ebay but the seller has flaked out and won't even respond anymore.
I've been doing research on this website but are there other reputable B&O resources that I should be referring to for vintage?
Thanks again!
