New gear and belt for the lid, and its nearly OK.
Only problem is when lid close, it makes a little "jump" 2-3 mm, then closes fully.
I changed the blue cap. on the motor control pcb 8. It was 20 uF so I changed it to
the right one 68 uF. But that was not good. When lid opens fully it makes a bad "krak.krak" sound. Gave it the old 20 uF then, opens fine witout krak sound.
Does anyone have a tip with the small jump at closing ?
Br Jens
