I was brought a BG4000 for repairs that was in about 40 pieces. At this point I have everything working as it should except for 1 issue.
The tonearm will not lower either with or without a record on the platter. If I push any of the buttons on the control and stop the tonearm, then push any button again, the unit will work as it should. If I turn the variable resistor on board 1 fully opposite, the tonearm will lower with or without a record on the platter. There is no happy in between.
All switches have been cleaned and measure around 0.1-0.2 ohms.
All power supply caps are new as well as 1C9 and 1C14
Hooking up a scope at 1TR14-1TR17 show signals nothing like shown in the manual.
I can also change the 6V output at 1TR19 by blocking the photocell in the tonearm.
I have been all over Beolovers site but havent found anything that helps.
Im going to try attaching some pictures of the scope signals.
The first is at the base of 1TR14 and the collector of 1TR17, (same signal) the second at the collector of 1TR14
Thank you in advance!
