Are the lids on the BG1500 and the BG3400 the same?
Craig🙂
Craig🙂
I have a feeling that it is not that simple! There is if I remember a height difference betwee the earlier and later decks.
Peter is as usual correct and it's actually a little worse in that there are (at least) three different part
numbers for those lids.
I seem to remember though, that one of them differs from the others merely by not having the tiny B&O
logo at the center of the lid but I don't remember for which Beogram(s) that goes and it's probably not
very important anyways.
Another thing is that many Beograms have had their lid replaced, some several times through their lifes
so you can't be sure that the correct type has been mounted.
Measure the lid height to make sure it's correct.
If the height is the same, it will fit.
