Hi, Martin!
First my apologies for starting two threads on my BG4002! I saw it as two different problems...should have stuck to one thread for one machine, I guess.😳
It's a BG4002 Type 5511. Here's what happened... Before I did anything, I made sketches and took pictures, just to be sure! I just got this unit, and the pickup arm motor was very noisy. I de-soldered the motor wires from the board and cleaned the motor. I also removed all connectors from the main board and cleaned all the pins, removed the board, visually inspected the components and attached everything again. All connectors were in place, just like in my reference pictures. All pins correctly inserted in the sockets, nothing sticking out on the sides. I was very thorough and checked that the colour-coded wires corresponded with my pictures.
When I installed the motor again, it ran backwards! When I pressed STOP the arm would move towards the platter centre spindle, and vice versa. And I hadn't mixed up the black and red motor wires. I re-checked my pictures several times: black-left, red-right. I noticed that the motor wasn't getting 12V any more, but 8-9V. So I resoldered the motor wires to the board, but reversed this time, and the arm moved correctly for a couple of minutes - and then the board stopped outputting any voltage at all to the tone arm motor. Everything else seems to be getting correct voltage, platter motor etc.
I have removed the motor again. No change, minimal voltage from the main board when I use the controls (typically 0.5-1.5V). The motor will run on a 9V battery, but is very noisy.
If I would venture to guess, I'd say that:
1. I did something to the motor that made it run backwards (but all I did was remove the rear plastic cap, clean the tiny contacts and re-assemble, making sure that the contacts were positioned on each side of the motor spindle).
2. I did something to the board that I just can't figure out.
3. One or several components on the main board failed in the process, causing the problem.
4. ...or something I can't think of!
I have removed the main board again and inspected it under a loupe for loose/cracked solder joints. I found three suspicious looking ones at the control panel connector, and resoldered them. But no change.
I'm sure you can tell that I'm just an adventurous amateur, and that I'm feeling my way forward here...😮
Again, any help greatly appreciated!
