greetings all,
I am in the middle of trying to revive one of my old 4002 tables.
apart from the broken shutter/servo globe that I am still chasing,
the table won't spin when '33' is activated ?
it starts and spins perfectly when 'On' is activated - speed change switching between '33' and '45' does also work fine!
FYI: at the moment there is no shutter globe fitted, which should have no bearings I presume ?!
as with this model, almost every connection between moduls is hard-wired, no plugs :-((
looking at the lay-out of the keyboard and what is actually happening when '33' is depressed, I would follow the violet wire to the main board ending near ( 1C1, 1D2, 1TR1) and or 1TR8.
are one of these components likely to cause that problem or am I far off the track ??
any assistance is greatly appreciated - as always :-))
cheers, ALF
