this one is going to be a bit tricky to explain: the erratic behaviour of my BG4000.
So far I have observed the following issues:
activate ON, the arm moves in one cm or two, stops and nothing else is happening ?
activate ON, the arm moves in about the same distance and lowers way before the dropdown point.
activate ON, the arm moves to to dropdown point, stops but nothing else. I I “finger-activate” the solenoid everything works on as normal.
activate ON, everything works normal as it should…and that can go on like this for half a dozen records without a glitch and then out of the blue is playing up again ???
in all those scenarios the main platter spins.
i am sorry, but I can not find any meaningful explanation for that behaviour or simply put don’t know where to start.
those brass contacts which may potentially be the source have been cleaned multiple times.
Perhaps one of you guys can make sense out of this - I would be very grateful indeed.
ALF
