Hello,
is it true that TX2 actually has Datalink build in the system but it just
isnt in use because of the RCA or DIN5 connectors? (somebody said so:)
If so, where can I find Datalink and how should I connect it to DIN7?
Thank you!!
JV
Hello,
Thank you!!
JV
Ok, thank you very much! By the way, what kind of cable it uses?
The cable to a DIN connector is 6 core with the yellow being datalink.
It is all illustrated in the service manual which you can download from this site if you upgrade your membership to silver or gold.
I have the service manual but Im not very good with diagrams..
What is the right place for Datalink cable inside the turntable?
I have to be sure before I start. Dont want to break anything..
