That Oneremote preamp has given me an idea but I’d be surprised if it works. The Beosound 4 has one disappointing feature – it only has standard RCA aux input, so no Beolink/Audio Aux Link. I do have a 1614 converter going spare though. Do you think if connected my BG3000 to the Oneremote device, then to the 1614 converter via A.Aux link cable, then to the BS4 via Masterlink, then I would be able to control my BG3000 via remote control?No I am pretty sure that this wouldn't work - the problem being that the BL1614 (or 1611) uses Audio Aux Link rather than the datalink that is needed to control the Beogram. There may be a (messy) solution using an MCL2AV - something like this but with your BS4 instead of Beoport: /api/files/3d3744a4624a4b5aa46d8c353e870b88 The diagram is madskp's work - hopefully he can comment further!
Ypou’re rifght – it doenslt work. I donlt yet have the adadter to connect my BG3000, but I didn connect the BG3000 to the 1614 via A.Aux link plug, then to my BS4 via Masterlink, just to test if there was any Datalink compatibility. There was not – if I pressed Phono on the Beo4 the BS4 came on (but in N.Radio, of course), but the turntable did not activate.There is a further complication with datalink, but I don't think it affected your experiment in this case: Tape and CD use pin 7, whereas Phono uses pin 6, unless RIAA is built in (to the Beogram) in which case it uses pin 7 also. (As an aside, the OneRemote RIAA must therefore swap datalink from pin 6 to 7). So your BG3000 probably expects datalink on pin 6, which corresponds to the AAL 'data' also on pin 6, albeit not able to control you Beogram in your test. Out of interest, when you tested this did you try putting the BeoSound in A.OPT 2 and then pressing DVD on the Beo4 - at the very least you should then get Beogram sound, but try controlling the Beogram also. Also, with the Beogram and Beosound running, try a long press on the Beo4 power button to see if it turns both BeoSound and Beogram off - if it does so then at least some data messages are getting through.
CharlieWednesday wrote: As for th alternarive possible MCL2AV solution you give – I did have an MCL2AV only recently but had to return it to the seller as it failed after a short while. Madskp’s diagram does have a note bottom-right though saying this solution would not work if a Beosound was used as the audio master, soi I assume Madskp means that my Beosound 4 is not an alternative to a Beoport in this case. I think that a Beosound cannot directly replace the Beoport because in his example the BL1611 is acting as the audiomaster (only a BL1611 can do this, not a BL1614), and effectively the Beoport is a link product. There may be a work around but I will have to defer to madskp’s greater experience of such setups!If this setup was to work the BS4 should be setup as a link room (option 5 or 6) and the 1611 would works as the Audiomaster (which is why the 1614 cannot be used). I just tried with my Beocenter 2 in option 5 - 1611 converter - MCL2AV in option 2 - Beogram. The commands would the be Link commands used for activating the Beogram in the main room" (the MCL2AV). However I can not get that to work, and I think I also have tried something similar when I made the different setup pages which might explain why I did not make one with a Beosound and the MCL2AV I can not figure out why it is not working as it should be possible to have a Beosound setup as a link room and get sources from a main room
