I could get a Beogram CDX with left hinge broken which I will be able to easily fix with a spart parts on Internet, but I have one issue : when I switch it on pushing the right "Play" button, nothing happens, no light.
I checked whether the power was coming through the cables, and yes.
Where should I begin ? I've seen there is a fuse, how to check if it is OK and how to change it ? I can't see how it works.
Attached is a picture of it.
Regards
Matz
